R settings
Antho
Gents this has me going mad and any help is appreciated . In normal mode my truck turns off when the breaks are pressed hard which I cannot stand. Why ford did this is infuriating. Ive read on this forum turning drive mode to sport stops this. So I set things to my favorite settings, sport mode, baha exhaust, turned off that annoying ambiance lighting and hit the R button. Next start up foes right back to all the settings that I hate. I checked my key settings and thats right, but does not remember my settings. Is there something im missing and doing wrong. Wifey has a tremor and has her own questions i cant answer right now.
That usless R button is to remember your settings. Im think that R button is for retard cause it does not remember crap
You don’t “hit” the button to save the settings. You have to hold it until it says it saved. Then every time you cycle the key off/on you just “hit” the button twice to load those settings. You can also save the auto start/stop setting in the R mode if you don’t want to use Sport. Hopefully it’s not for retards if you can’t even figure it out.
See screenshot from your owners manual.
Donmatteo
Santa Clarita / Coronado
Thanks for posting this. Clearly the manual is smarter than some owners that post on this forum.
Azurebeast
Azurebeast
Stroudsburg PA
Yes, just thought when you set up the MY KEY it would automatically go to the settings on the key.
DougDimmadome
East PA
When you first start the truck, it will always default to normal mode with auto start stop on without user input.
It’s designed that way on purpose and there’s no way to change it on the F-150s. You can thank the EPA for that.
