Question on WSI bed mount with Rigid?
SwampKing
I have 84" to clear in my garage. U guys think I can pull off this rear light rack on mid perch running 37"s?
Method NV/37's
Boatec front and Rear fenders
Rigid dually's in fogs
FOR NOW!
Labraptor
Illinois
I only have stock 35" but I will try to get an accurate measurement on mine in the morning.
If you measure your cab height I can measure projection above cab too. Will allow you to ignore any slight height variance and eliminate guess work on height with bigger tires. Hope that I made sense. Too tired, will measure in am.
Sent from my DROID4 using Tapatalk 2
T
TAZMAN
North Salem IN
We did some measuring last night and I only have 5" of clearance above the flat part of the cab. I am running the Falken Wildpeaks which are true 35 inch tires and the mid perch setting. I may not be able to clear the light bar set up I want?
Labraptor
Illinois
Didn't measure this morning but, better late than never. From highest point on my roof to the top of the lights is 4 1/2 inches. While I was at it I took night pictures with lights on and sunroof cover open.
Pictures from drivers seat, back seat and camera pointed straight up at sunroof.
Crap, just noticed I accidentally posted a picture that I took before turning the flash off. Will upload different picture.
