question about DRL color
swoop1156
USA
Just to clarify my previous statements the upside L-shaped light does not light up at all only when I turn on the indicators.
I assume from your answers this is a software issue.
Got you! Yes, you can have those light up as DRL. It is indeed changeable through a software program called FORScan.
I am on mobile right now so I will not have the opportunity to find the thread I am referring to, but if you look in my post history there is a member here from UAE that had the same problem. We walked him through how to enable it using that software program.
You will also need a specific OBD-II connector available readily online.
When I get a chance, unless you find it first, I will go back and link you the thread.
Donmatteo
Santa Clarita / Coronado
Yeah I know what he said, but also tossed out another opinion. It's all good man, chill.
If importation was after it was built as a US-spec, it's really interesting that there's white Raptor specific parts out there, or a shop doing the conversions. Never heard of it before, and it ain't the first Raptor in the EU, and I've not seen any of those with white front-facing running gear.
I'd love to see the AB data through the VIN to see what other changes may have been done, like rear facing fogs, for example.
Definitely need some pics of the rig!
all good dude.
I'd love to see the work order just out of curiosity.
swoop1156
USA
all good dude.
Absolutely! Looks like the AB data will shed light on what changes were done. We can definitely get it working once we have that.
Check the settings for DLR's. There is an option to turn them off. I THINK, that might be your issue.
It could possibly be that easy, though if his truck is anything like the truck in UAE, that option was actually enabled in the settings of the vehicle, but the module would not recognize it.
It was a simple FORScan change from one value to another and it worked. It's just a pain to have to get the program, the adapter, get a license, just to make that change.
swoop1156
USA
S
sperminator
Hungary
I have already checked it and watched a video from Ford's website but in the lights setting, there are no options for DLR.
I think it was taken out of the software.
swoop1156
USA
Hey, check this link and see if you can make sense of it. There's quite a bit of conversation regarding your issue between me and another member here.
You will have to download your AB data, and open it in notepad and then search the module number and then compare values.
Regardless, you can't change any of that until you have the program FORScan. With it, you can do a ton of different things.
I hope this helps!
