Question #11: So what is it gonna be, Crazy?
Frank N
NJ and Outerbanks
So I need to man up and get the 17's with beadlocks to go between?
Or you can wait if you prefer the 17/18 version of beadlocks and get them off ebay.
I got a second set to convert to real beadlock....for when I absolutely must travel at excessive speed on the beach
54a60dd4-9ab3-4a5d-97c2-437fd3782922-jpeg.146044
BroncoAZ
Cape Cod, MA
In all my years of offroading, I've only ever lost a bead once. I had to drive off the trail to avoid a mountain biker and I hit a rock that pulled the tire off the bead while cutting the sidewall bad enough it required tire replacement. Unless you're running under 25 psi at high speed I can't see a need for beadlocks, under 25 psi you'd probably overheat the sidewall and damage the tire anyway. Using the same 315/70R17 tires on my 5500# Bronco I found that 18 psi was the sweet spot for crawling and general trail use. For high speed wash or dirt I was good around 25 psi.
911 Crazy
911 Crazy
Maine
nice
Frank N
NJ and Outerbanks
up to 50-60 MPH in rutted sugar sand at 18-20psi, and slower speeds as low as 12 PSI
sidewall damage? Yes, thats why I am mounting my old ko2s on the BL set and run two spares
Are they absolutely necessary for what I do, after 20 years of beach driving, no, but they look damn good and it gives me some more flexibility for really lowering tire pressure if I want or running harder with less worry
These are my second set, not my daily driver set.
TXRaptor
Should we warn the guys over at shelbyconvertibleforum.com of the coming blight?:D
Yes! I have already posted a warning on the Shelby forums over at Mustang6G to watch out for any new member with 911 in their name, just in case he decides to go with a current gen Shelby.
