this may help any one else looking to do the install.
i used various resources to find the right wires. the colors changed in 2011 mines a 2012 but 13s and 14s may be different too
Great Walk thru But for a FRS or BRS so a lot of differences in wiring etc but I found it useful
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB
2010 Wires:
H1/1: Trunk Output - N/A
H1/2: +12v Constant - (PUR/RED at Ignition Harness)
H1/3: Siren*
H1/4: Park Light Iso - N/A
H1/5: GND
H1/6: (+)Door Trigger - N/A
H1/7: Trunk Pin - N/A
H1/8: (-)Door Trigger (Diodes on the 4 doorpin wires in SmartBoxJunction)
H1/9: Dome Light - N/A
H1/10: Turbo Timer - N/A
H1/11: Park Light Output - (PUR/WHT at SBJ)
H1/12: GND Armed - N/A
H3/1: IGN 1 (WHT/ORG at Ignition Harness)
H3/2: Flex Input - N/A
H3/3: ACC (PUR/GRN at Ignition Harness)
H3/4: Starter Out (BLU/WHT at Ignition Harness)
H3/5: Starter In - N/A
H3/6: IGN 1 Input (PUR/RED at Ignition Harness)
H3/7: Flex Out - N/A
H3/8: Flex In - N/A
H3/9: ACC/START Input - (PUR/RED at Ignition Harness)
H2/6: 200a Aux Output (Rear Defroster wire behind radio)
H2/8: Horn Output (BLU/WHT at Steering Harness)
H2/10: Status Out (PKALL (-) while running)
H2/11: Hoodpin (Hoodpin (GND when opened)
H2/17: Brake Input (PUR/WHT at Brake Harness)
H2/18: Neutral Safety (GND)
Perfect write up for wire locations but, for a 2010 all my wire colors were different:
https://www.f150forum.com/f38/2010-remote-starter-wiring-info-pics-match-71887/
2012 Wires:
Item*****Wire Color*****Polarity*****Wire Location
12 Volts*****GREEN/ red (15A)*****+*****ignition switch, black 7 pin plug, pin 4
Second 12 Volts*****red (30A), blue/red (30A)*****+*****BCM, black 32 pin plug (D), pins 6 and 1
The BCM (Body Control Module) is in the passenger kick.
Starter*****blue/white*****+*****ignition switch, black 7 pin plug, pin 7
Second Starter*****N/A
Ignition*****WHITE/ orange*****+*****ignition switch, black 7 pin plug, pin 1
Second Ignition*****N/A
Third Ignition*****N/A
Accessory*****PURPLE / green*****+*****ignition switch, black 7 pin plug, pin 6
Second Accessory*****N/A
Third Accessory*****N/A
Keysense*****blue/gray*****+*****ignition switch, black 7 pin plug, pin 5
Data Bus*****yellow/orange (TX), PURPLE / gray (RX)*****data*****PATS Transceiver, black 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition is PURPLE / orange in pin 1, and ground is black in pin 2.
Can Bus High*****gray/orange (MS CAN); WHITE/ blue (HS CAN)*****data*****data link connector, black 16 pin plug, pins 3 and 6
Can Bus Low*****PURPLE / orange (MS CAN); white (HS CAN)*****data*****data link connector, black 16 pin plug, pins 11 and 14
Can Bus Sw*****N/A
Power Lock*****blue/green*****-*****BCM, gray 26 pin plug (C), pin 6
Power Unlock*****yellow/purple*****-*****BCM, gray 26 pin plug (C), pin 8
Lock Motor*****gray/brown*****5 wire*****BCM, black 32 pin plug (D), pin 26
Driver Unlock Motor*****blue/green*****5 wire*****BCM, black 32 pin plug (D), pin 21
Passenger Unlock Motor*****PURPLE / gray*****5 wire*****BCM, black 32 pin plug (D), pin 31
Parking Lights (-)*****gray*****-*****headlight switch, gray 10 pin plug, pin 2
May need to interrupt the headlight switch ground when triggering this wire. It is black at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+)*****yellow/blue*****+*****BCM, gray 10 pin plug (E), pin 6
Hazards*****BROWN / yellow*****-*****BCM, black 52 pin plug (B), pin 32
Turn Signal (Left)*****blue/green (F); gray/brown (R)*****+*****BCM, brown 26 pin plug (F), pin 8; black 32 pin plug (D), pin 12
Turn Signal (Right)*****yellow/purple (F); PURPLE / orange (R)*****+*****BCM, brown 26 pin plug (F), pin 7; black 32 pin plug (D), pin 15
Headlight*****yellow/blue*****-*****headlight switch, gray 10 pin plug, pin 7
AutoLights*****PURPLE / green (interrupt to turn off autolights)*****-*****headlight switch, gray 10 pin plug, pin 4
Reverse Light*****blue/white*****+*****BCM, black 32 pin plug (D), pin 13
Left Front Door Trigger*****GREEN/ purple*****- N.C.*****BCM, gray 26 pin plug (C), pin 9
Right Front Door Trigger*****white*****- N.C.*****BCM, gray 26 pin plug (C), pin 5
Left Rear Door Trigger*****green*****- N.C.*****BCM, gray 26 pin plug (C), pin 20
Right Rear Door Trigger*****yellow*****- N.C.*****BCM, gray 26 pin plug (C), pin 21
Dome Supervision*****gray/purple (dome lamp); purple (puddle lamp)*****+*****BCM, gray 12 pin plug (A), pin 1; gray 26 pin plug (C), pin 1
Trunk/Hatch Pin*****N/A
Rear Glass Pin*****N/A
Hood Pin*****blue/orange*****- N.C.*****BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release*****N/A
Trunk Release Motor*****N/A
Fuel Door Release*****N/A
Power Sliding Door (Left)*****N/A
Power Sliding Door (Right)*****N/A
Factory Alarm Arm*****PURPLE / green and YELLOW /GREEN (driver door keypad)*****both -*****BCM, gray 26 pin plug (C), pins 18 and 11
Factory Alarm Disarm*****see disarm no unlock
Disarm No Unlock*****Transponder and ignition
Trunk Alarm Shunt*****N/A
Tachometer*****NOT blue*****ac*****any fuel injector
The injector wire colors are GREEN/ blue, gray / YELLOW, PURPLE / gray, yellow/orange, brown, GREEN / WHITE, gray/brown, or PURPLE / orange.
Wait to Start*****N/A
Neutral Safety*****N/A
Clutch Pedal*****N/A
Fuel Pump*****PURPLE / green*****+*****driver fender, black 34 pin plug, pin 15
Rear Defroster*****BROWN / blue*****- latched*****driver kick, dk. gray 22 pin plug, pin 20
Mirror Defroster*****same as rear defroster
Left Front Heated Seat*****WHITE/ blue (with heated only)*****-*****HVAC Module, gray 26 pin plug, pin 18 or black 26 pin plug, pin 5
Right Front Heated Seat*****gray / YELLOW (with heated only)*****-*****HVAC Module, gray 26 pin plug, pin 17 or black 26 pin plug, pin 4
Speed Sense*****yellow/orange (3.5L) or BROWN / green*****ac*****PCM, 95 pin plg (E), pin 12 (3.5L) or 50 pin plg (T), pin 25 or 14
The PCM (Powertrain Control Module) is in the engine compartment, on the passenger firewall.
Brake Wire*****PURPLE / white*****+*****brake switch, wht 4 pin plug, pin 1 or BCM, blk 52 pin plug (B), pin 28
Parking Brake*****WHITE/ purple*****-*****parking brake switch or BCM, gray 26 pin plug (C), pin 7
Horn Trigger*****PURPLE / green*****-*****horn switch, blk 26 pin plug, pin 8 or BCM, blk 52 pin plug (B), pin 33
Wipers*****(LIN bus)
Left Front Window (Up/Down)*****(motor is part of module)
Right Front Window (Up/Down)*****(motor is part of module)
Left Rear Window (Up/Down)*****blue/orange - yellow*****A*****driver kick, door harness
Right Rear Window (Up/Down)*****gray/purple - BROWN / green*****A*****driver kick, door harness
The power sliding rear window open/close are PURPLE / brown - yellow/orange (5 wire) at the overhead console switch, gray 12 pin plug, pins 4 and 9.
Sun Roof (Open/Close)*****pur/brn - yel/org (function with ignition on only)*****-*****overhead console switch, gray 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close)*****N/A
Memory Seat 1*****PURPLE / white*****-*****memory seat switch, black 8 pin plug, pin 2
Memory Seat 2*****yellow*****-*****memory seat switch, black 8 pin plug, pin 6
Memory Seat 3*****N/A
Radio 12V*****gray/red*****+*****radio, gray 24 pin plug, pin 1
Radio Ground*****BLACK/ blue*****-*****radio, gray 24 pin plug, pin 13
Radio Ignition*****gray/blue (base radio only; MS CAN on premium)*****+*****radio, gray 24 pin plug, pin 2
Radio Illumination*****PURPLE / gray (base radio only; MS CAN on premium)*****+ dimmer*****radio, gray 24 pin plug, pin 3
Factory Amp Turn-on*****PURPLE / red*****+*****radio, gray 8 pin plug, pin 4 or gray 24 pin plug, pin 7
Power Antenna*****N/A
Left Front Speaker (+/-)*****white - WHITE/ brown or green - gray*****+,-*****radio, gray 24 pin plug, pins 8 and 21
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the amplifier, gray 16 pin plug, pins 2 and 10. The tweeter wires are GREEN/ orange - gray/orange at the amplifier, gray 16 pin plug, pins 3 and 11.
Right Front Speaker (+/-)*****WHITE/ purple - WHITE/ orange or purple - yellow*****+,-*****radio, gray 24 pin plug, pins 11 and 12
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, gray 16 pin plug, pins 6 and 14. The tweeter wires are PURPLE / orange - yellow/orange at the amplifier, gray 16 pin plug, pins 7 and 15.
Left Rear Speaker (+/-)*****WHITE/ green - BROWN / yellow*****+,-*****radio, gray 24 pin plug, pins 9 and 22
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, gray 16 pin plug, pins 4 and 12.
Right Rear Speaker (+/-)*****BROWN / white - BROWN / blue*****+,-*****radio, gray 24 pin plug, pins 10 and 23
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, gray 16 pin plug, pins 8 and 16.
Center Channel (+/-)*****green - gray / YELLOW*****+,-*****amplifier, gray 16 pin plug, pins 1 and 9
Subwoofer (+/-)*****PURPLE / green - GREEN / WHITE (1); grn/pur - gray (2)*****+,-*****amplifier, blue 16 pin plug, pins 1 and 9; 2 and 10
Aux. Audio Input Left (+/-)*****blue - YELLOW /GREEN (without SYNC)*****+,-*****radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-)*****blue/green - WHITE/ green (without SYNC)*****+,-*****radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-)*****BROWN / purple - WHITE/ green (front display w/navi)*****+,-*****radio, gray 10 pin plug, pins 3 and 8
RSE Audio Left (+/-)*****blue - gray/orange (SYNC audio)*****+,-*****radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-)*****PURPLE / green - BROWN / white (SYNC audio)*****+,-*****radio, gray 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts*****N/A
Satellite Radio Ground*****N/A
Satellite Radio Ignition*****N/A
Satellite Radio Antenna*****N/A
Satellite Audio Left (+/-)*****N/A
Satellite Audio Right (+/-)*****N/A
Item*****Size*****Depth*****Location
Headunit*****irregular center of dash
Left Front Speaker*****6 x 8*****3*****left front door
Left Front Tweeter*****1*****1*****left front pillar
Right Front Speaker*****6 x 8*****3*****right front door
Right Front Tweeter*****1*****1*****right front pillar
Left Rear Speaker*****6 x 8*****3*****left rear door or side panel
Left Rear Tweeter*****N/A
Right Rear Speaker*****6 x 8*****3*****right rear door or side panel
Right Rear Tweeter*****N/A
Center Channel **top center of dash
Subwoofer*****8*****3*****under rear seat
Left Front Headrest **
Right Front Headrest **
Left Rear Headrest **
Right Rear Headrest **
Satellite Radio Tuner*****(built into radio)
More for 2012 – According to this site all 2012+ are the same wires so that may be true.
2012-Â*FordÂ*F-Series Light DutyÂ*Vehicle Wiring Chart and Diagram
For the Can BUS I read multiple horror stories and c=multiple install giuide say do noy use a tape or connector on the CAN BUS just to strip som wire away and wrap the bare wires around the exposed CAN BUS Wire and wrap in electrical tape. No solder or tab or butt connector. Works great for me.
image1 by
ASarsano, on Flickr
