Decided to become a vendor and start offering the XRD Bed Rack and also added a second product, the XRD Fuse Block Plate. Please click on the link in my sig if you'd like to see more pictures.
Pricing will be available within the next few days - Thanks for being patient!
looks really great, could this be mounted with a bedrug?
There's no bolt to do on the rear it literally just slides in. When you bolt to the cage in the front it pushes towards the rear just enough to make it snug. So I guess 2010 guys would just need to drill the 5/8's hole and be good to go. Hopefully someone takes a pick of the bed back there so I can see. I'd have to retract the "100% bolt in with no modifications to the bed" statement otherwise. Removing the rear lights would be meh as well.
That's the one!The side rail doesn't hang on that hole like you'd think as it gussets with the rail brackets in the front more pushes against the side bed snuggly than anything else.
Thinking I should just make a quick video later today. Pictures only do so much.
I think I've got a crude understanding?
-Base rack bolts to bed using factory bed bolt locations.
-Forward rack bolts to base rack
-Side racks slide into rear hole and bolt to forward rack
Is that about right?
