Well, it's been about two weeks since the last update on the Bed Cage/Rack due to life in the form of my son shattering his left arm falling off his bike and me getting the stomach flu while at CHOC. Anyways - Rack is back from powder coat and took the 30 minutes or so for installation. Also weighed the entire rack which tilted the scale at roughly 80 pounds. 40ish for the main base and 20ish for each side rail. It was lighter but I decided to reinforce the side rail plates for that added umph. Also re-designing the mounting points to make it easier for the end user and installation if this goes into production, which also gives a little more mounting room for water users want.
So see the pictures below and let me know if you guys would be interested in something like this and I'll go forth with the Vedoring stuffs and pump a few of these out
Fresh from Powder coating:
Back View:
Removal of the 6 bed bolts and placing the base: (the base will be more square towards the front for easier installation for the end user which adds more grate space for mounting whatever you want.)
Inserting side rails: (This is for a 2013, I need pictures of this location for 10's - 12's to see if it's the same)
Reinforced rail plates: (it's not going anywhere)
Loosely tightening and lining up to primary base: (There will be some play here in order to line up and tighten everything)
How it looks installed:
Side rail shot:
Just put two things on to show a possibility: (Again, this is designed for you to put whatever/however you want on it, will vary with user *it's not set in stone* the black box on the right is for a secondary battery)
I'll be spending the next week or so mounting my expedition specific stuffs. Production ones will have pre mounting holes in the middle for a spare tire add on if individuals really want to add a tire horizontally. The vendors here on the site have better solutions for you if you want to mount them, more than one, vertically. I designed this to work with a bed cover but doesn't mean you need to have one.
Back View:
Side rail shot:
