Protecting your Raptor in the Winter from Corrosion
911 Crazy
Maine
? How long would it take to do the entire truck? I think I'll do mine in Virginia before heading home.
Big Blue
Big Blue
Administrator
Staff member
Admin
USA
I would imagine it would not take more than an hour to spray the full undercarriage, maybe 1.5 hours max. I recall when I did it last winter, I gave it a spray then came back to hit any spots I missed the first time.
This year I am doing a combo and will use the Fluid Film on the Fox 3.0s and Amsoil everyplace else.
CobraJay
Tweaker by trade
NE Ohio
I've been using NH Oil (clear) the last couple years.
I considered them but decided to try Wool Wax first, I do however like their "Salt-Brine Eliminator" and used it prior to my coating this season. Gave 2 solid rinses on my wifes Legacy and the Raptor and probably have another couples years worth of it.
How does it hold up in high wash areas???
Badgertits
Ma
I truly don’t understand why you would use wool wax or especially fluid film over the amsoil product
fluid film on the shocks? Why? They’re not going to just rust & by the time they start getting grungy would need a rebuild & you’ll have brand new looking ones on then-
Check out the Yamashield folks
Jughead
SW. Pa Part of the Rust Belt
I think this would be an annual event. I used it on my old rubicon but it was too far gone at that point. I think it was pretty much done after winter.
I put NH on much heavier than how they show in their videos.
I'm starting new on my raptor so no precleaning is necessary. I have an undercarriage sprayer that attaches to my power washer I use in the spring. Again I started using this on cars that already had a ton of miles on them
CobraJay
Tweaker by trade
NE Ohio
Good point, will try put some Yamashield next season for the shocks. But at the rate Im driving while working from home its going to be a while before a rebuild lol. Use to log about 20k miles a year, dont think I will break 8k now.
Olsen Motorsports
Downers Grove, Illinois
I have always used Lear Chemicals ACF-50 have never tried the above mentioned stuff. Always had great results with it! But now my interest is spiked! This stuff seems a lot more readily available!
I have always like the ACF-50 on magnesium and bare aluminum because it corrodes so easily
911 Crazy
Maine
  • I'm leaning toward Amsoil, beside the red tint, is there anything or anywhere I can't spray? Stay away from painted surfaces as it's petroleum based.
  • Do you spray on just like you would when you paint something w a can of aerosol paint? Yes
  • Do you need to cover anywhere else on the vehicle or the ground while you're painting? I didn't since your only doing the undercarriage.
  • Does it drip and go everywhere, or is there any overspray? No not really and it includes a thin straw for tight areas.
  • How thick, or how many coats do you put on? Only one coat is needed but be sure to cover everything which is the one advantage of the red tint, you can see what you missed and what you coated pretty easy.
  • Does it have to sit and "cure" before you can drive it? I let mine sit for at least an hour to dry.
  • Is there a point below a certain temp where it's too cold to spray on outside? Can I spray in the garage? Do it before it gets too cold, like this week and yes you can do it inside. The Amsoil does not smell bad at all.
So for a first time for any protectant on the truck, how many cans of each would you propose?
