OrangeAddict
I have read alot on the forum and other places that beadlocks are not meant for on road driving. I have the beadlock capable rims and frequently air down the tires for driving on the soft sand around the beach. That is typically only 18 to 20 PSI which I think I don't need to worry to much about loosing a bead, but I have seen it happen if someone gets a little to heavy on the skinny pedal. So the question is to put on the beadlocks and run them as a normal tire against the wishes of FORD or to end up later getting "street" tires and rims and having a separate set of "off road" tires and rims. What problems occur when running beadlocks on the road?
