Nice.... where did you get it cut and programmed ?
Nice, just curious what a dealership or local locksmith charges to program this keys
2. Place the first programmed key in the backup position
3. With left hand, Press Start\Stop button
4. Counted to three maybe four seconds (one one thousand, two one thousand, three one thousand)
5. With left hand, pressed Start\Stop button
6. With right hand, swapped first programmed key with second programmed key (quickly)
7. With left hand, pressed Press Start\Stop button
8. Counted the three maybe four seconds (one one thousand, two one thousand, three one thousand)
9. With right hand, swapped second programmed key with the un-programmed key (quickly)
10. With left hand, pressed Start\Stop button
11. Door locks cycled and dashboard light up and dashboard counsel stated “Key Programming Successful”
I might be wrong but if you only have one key then I think you can use forscan to program a new key. Not sure though.I know you can program yourself with two working keys, I was under the impression you only had one working key and in that case you have to take it to a dealer or locksmith
Bought it from eBay, new OEM: https://www.ebay.com/itm/NEW-OEM-17-2018-2019-2020-FORD-F150-RAPTOR-REMOTE-START-SMART-KEY-FOB-164-R8185/114018420534?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I haven't gotten the key cut yet, i'm sure I can just go to a local locksmith and have them do it. They did it on my Subaru when my fob broke. If they can't for whatever reason it's not a big deal.
