GEN 1 Procharger Running!!!
jokerz
Now I had this procharger built with straight cut gear and a race blow off valve. Extremely loud. It's Making a clattering sound. I have 8 ounces of supercharger oil in the procharger. So that checks out. If it's normal I'll let it be.
Possible causes belt to tight. My first but I have backed it off already .
Bad bearing from factory?
Belt alignment. Seems on and ok
If this sound is typical from these on the raptor platform I'll give it hell
https://vimeo.com/173979409
https://vimeo.com/173979433
beemerman
Worlds most famous beach
That does not sound right. Almost sounds like a loose bracket. Or maybe a bearing in the unit. One of my customers had a pro charger. Did not sound like that. I think the straight cut gears would give it more of a whine. Just my opinion.
jokerz
jokerz
http://youtu.be/g1trLIK-hCs
This one has an odd sound as well
jokerz
jokerz
I have straight cut gears. tomorrow I'm going to remove all the tension that I can off the tensioner
jokerz
jokerz
Loosened belt no change I have 3/4" of slack in the belt. Was set at 1/4".
---------- Post added at 01:37 PM ---------- Previous post was at 01:26 PM ----------
Getting this insane bearing rattling noise coming from the idler supercharger area. So I have some questions.
Are there any self adjusting tensioners for the procharger kit? Mentioned here.
http://ls1tech.com/forums/forced-induction/518969-need-help-procharger-noise-pulley-issue-pics.html
It seems the ls guys have the same issue. It seems it's the load on the bearings and idlers and the material they are made of may be part of the sound. But he sound is common from what I have been reading.
How much slack do you guys have in your belt between the alternator then the idler that goes to the Ac compressor. I have 3/4 of an inch there. Then from the procharger to the power steering pump I have 3/4". I read anywhere from 1/2"-1" was acceptable. I had about a 1/4" of slack before I back it off this morning.
I'm just overly picky making sure I didn't mess something up so I'm tracing my steps backwards.
