Pro Eagle Jack Problems
Erjdrvr
Indy
Hey guys, I've got a 2 1/2 year old Pro Eagle 2 ton big wheel and one of the 2 spring pump pistons is sticking in the down position. I can take a screw driver and eventually get it to return.
So I called Pro Eagle yesterday & the lady said the entire pump is not serviceable. So you must purchase a new pump for $60. Has anyone had similar problems and had any luck trying to repair or rebuild their pumps?
Pretty disappointing considering the cost & reputation of these Jack's!
https://www.fordraptorforum.com/threads/pro-eagle-great-customer-service.76450/#post-1487424
Troubleman
Alabama
Wow, I’m glad that I’m seeing this because I’ve been eyeballing these jacks even prior to purchasing my truck. It’s better to have something that nothing but you’re right, for that price it seems like the pump should last for a long time. How often have you used that jack and did you mount it within the bed of your truck?
Thomas_JohnDoe
Chicago
imo pro eagle is overrated, its just a cheap Chinese made jack with big wheels, btw I have the same 2 ton sitting it the bed of the truck
Erjdrvr
Erjdrvr
Indy
I had it in the bed of my old Gen2 for almost 2 years. I have 2 sets of tires so I would use it 3-4 times a year. Since receiving my Gen3 in mid Sept. I've probably used it maybe 10 times.
Erjdrvr
Erjdrvr
Indy
Guess so...explains why they don't offer a rebuild kit!!
I've also been researching the Harbor Freight jacks. Although once you spend the bucks to convert to big wheel and add mounts the price gets up there!
Thomas_JohnDoe
Chicago
I have HF jack too, its over 10 years old and it never gave me a single problem. It looks like Eagle took HF jack put on big wheels, marketed the **** out of it and added $400 on top of it
jm77
USA
Sounds like the OP has another issue, but my pro eagle needs to be bled from time to time. Open the valve 2 turns, 10 pumps and its back to normal. Maybe hit the outside of the valve with some spray lube and try to work it in? Mines been mounted in the back of my truck for years and thats what I do from time to time.
