Pre Lube pump to prevent Cam Phasor Failure?
jskrebs
After just having the 2nd set of Cam Phasor replacements at 118K I am considering a pre-lube pump to ensure the phasors always have sufficient oil pressure.
I can find pre-engineered kits for industrial engines and I was hoping someone else had built up the proper BOM for the Raptor.
Curious to see if anyone is ahead of me on this.
Jeff Krebs
2018 Ruby Red SCAB w118K
FordTechOne
Detroit
Priming the oil system before starting will not prevent or resolve the issue. As long as you have the new software (recall 21B10) the premature wear of the phasers is prevented.
J
jskrebs
I think they did the firmware update with the 2nd set of Phasors.
I do notice the truck cranks for a second or so before firing the motor where it fired instantly before. Assuming this allows oil pressure to build.
dspangler
Vermillion
I am surprised nobody has made a cam phaser delete kit for the 3.5 like there is for the 4.6 and 5.4 engines.
Jeff Krebs
Halo Raptor
Monrovia, CA
Just prime it yourself. If you hold down the gas pedal, then hit the start button the truck wont start but will kick over. Once the motor has turned over for about 5 seconds, let off the gas pedal and it will start. It will be fine, no rattle. This is how Ford primes your cam phasers the first time they start it after install. Only need to do this on cold start usually.
FordTechOne
Detroit
You just can’t stay out of the Gen 2 threads can you Sasquatch.
The main purpose of VCT on 4.6/5.4 3V and 6.2 was to provide EGR function. That’s why they can be “deleted” with little to no loss in power or drive ability.
You can’t run a delete kit on an otherwise stock engine when the VCT system is integral to engine performance like it is on EcoBoost and Coyote applications.
FordTechOne
Detroit
That’s most likely related to learned parameters being reset. A properly functioning VCT system does not need oil pressure on a cold start.
scpete24
SoCal
I was going to say is this guy bat **** crazy or what. Glad you beat me to it
