Power steering hose leak
sandtrooper29
sandtrooper29
Lubbock, TX
I had the same issue. I finally took the whole thing off and tighten everything up. That away I could really tighten them.
TXRPTOR37
Just finished taking it apart and took the fitting off. Reassembled and tightened everything. Will drive it shortly and see if it leaks still. Fingers crossed.
JRaptor11
Maryland
I got the leak happening too. Installed mine and tightened the fittings pretty good but still some leakage. There is a small little hole on the fitting nut that seems to have fluid dripping out of it.
NickPic83
Rockland County NY
Make sure they are all cranked tight. If the fittings dont bottom out they will leak
JRaptor11
Maryland
Geez, now I have a slight popping sound when I turn my wheel at low speeds.
The Macf
Vegas
I had to crank the **** out of my RPG. Like so hard the whole reservoir was coming up.
