Power Steering Blowout & Failure!
Yukon Joe
Trafford, PA
Ok final update.
The dealer replaced the two pulleys. The tensioner and the idler pulley above it. Remarkably that was what was causing the whining noise. I'm relieved that it wasn't the power steering pump. It sure sounded like it. I had the belt tensioner replaced earlier this year (spring). So I suspect it was the idler making the noise.
Night Raptor is finally home and I'll be able to get some prep done for snoball. Looking forward to getting the Duratracs back on and the O2 sensors spacers installed.
Donate to Avery and be entered into a raffle for an awesome prize for your Raptor.
TRAIN HORNS!!! Thanks to Hornblasters.
http://www.fordraptorforum.com/showthread.php?p=801448
Hole Shot
Raeford, Nc.
Mine has started to whine again now the cold is starting to set in. It just does it for a min or so b
Yukon Joe
Trafford, PA
Apparently that is what mine was doing. It would warm up and settle down. Check the tensioner for the noise.
FordService
...The dealer replaced the two pulleys. The tensioner and the idler pulley above it. Remarkably that was what was causing the whining noise. I'm relieved that it wasn't the power steering pump...
Thanks for the update, Yukon Joe; I'm glad your dealership got you fixed up! :)
Mine has started to whine again now the cold is starting to set in...
It might be time to get this in front of your dealership, Hole Shot. If you'd like, you can wait for a very cold day so you won't have any issues replicating it for your tech. How many miles are on it?
Crystal
Hole Shot
Raeford, Nc.
Mine is a 2011 with just under 60,000 miles I have already replaced the power steering pump One I am sure that my truck is out of warranty and most of the time I do all my work myself that being said I have never seen somebody do what you do and On be half of all the people you help on the forum I just want to say thanks and merry Christmas !!
naptown
naptown
Annapolis, MD
Well, this is an old thread, but my Power steering pump went up again!! Last weekend having off-road fun in the snow, it craped out again! Truck is back in the shop. This will be #4 replaced. WTF! I need a real fix for this issue. Anyone have a solution! So frustrated
