Ruger
That's nice, but the engine doesn't have an airflow sensor (MAF) at all. It has absolute pressure sensors and in basic terms, the airflow is estimated based on the manifold pressure, the actual throttle plate position (not the pedal) and the rpms...
It is quite accurate if the initial Volumetric Efficiency (VME) calculations are set up properly.
Thanks, didn't know that. I wonder if an excessively oiled air filter can gum up the pressure sensors the same way it can an airflow sensor.
