I'm going to splice into the wiring for the OEM horn to add a relay that will enable to use the factory horn button to blow an air horn I installed. There are two wires going into the horn harness which I assume is (+) and ground. I don't have access to a voltmeter right now so was hoping someone could help me with the polarity of the wires. Is the Red wire (+) and the black wire ground as logic would dictate. I don't want to make any bad assumptions and only want to cut the (+) wire for the relay.
I'm wiring the relays as follows to allow the factory horn to be active when upfitter switch is off and air horn to be active when upfitter switch is not on. Please let me know if something doesn't look correct.
Pin 30 - (+) wire from OEM horn button
Pin 80 = (+) wire from upfitter switch
Pin 85 = ground
Pin 87 = (+) wire to air horn solenoid
Pin 87a = (+) wire to factory horn
Pin 85 = ground
