GEN 2 Permanent ORV Flag Mount Question
Spartan1
Mars
I would still rather have the one first posted in this post
It looks like a good idea. When the tow hook mount ones loosen up they either fall forward or backwards and smack the shit out of the truck. A second point of connection up higher might be a good idea. The bungie card and some foam idea works but there has to be a better way. I suppose that if the bracket is long enough then the flag pole won't hit the truck.
Swarfworks
Michigan
Swarfworks, are you selling those flag mounts?
I make one that attaches to the tow hook. The one that I posted at the beginning of this thread worked great, but didn’t seem like many people wanted to go through the work of cutting the hole in the bumper grill. Here’s my solution that works great.
highway420
Do you still have any of these? I would like one and your license plate re-locator. Which I am a little upset at myself for not knowing you had this.
POOPonYOU
Paramount, Ca
Yes, they should work. The license plate relocation mount works on the Gen1 as well. Thanks!
I'm going to buy the mount from your website for the front tow. Is there a 2 piece rod that you recommend to work with your product? The top of the rod has to be at least 8' from the ground. I'm going with a 2 piece unless you think a 1 piece rod will fit in the bed of the truck.
