Perch Mod Discussion
Mid perch or no?
  • Total voters
    426
Phyguy
Denver, CO
Down in Englewood....basically around Santa Fe and Oxford. here's the website: High Country Performance 4x4 Denver, Colorado Parts and Maintenance for 4x4 Vehicles
I was half watching the dude through the shop window while I was there. When he finished up installing the lines (before flushing and bleeding) he sprayed something all under my truck from a can. I couldn't for the life of me figure out what it was. Then, after bleeding and backing it out of the bay (but before taking it for the test drive) he took a high pressure hose to the undercarriage.
When paying, I told the mechanic and cashier that I noticed what he was doing and I asked if that was a teflon spray of some sort. He mentioned it was brake 'cleaner' that is water soluable after a brake job. hence the high pressure hose down afterward.
Above and beyond or standard practice?
SOCOMech
Famous Raptor
Phoenix AZ
Why in the world did he have the brake lines open?! Absolutely no need for that to do this and you may have paid more in labor for it. Otherwise, yes, brake clean is a mechanics best friend and often used to clean up even the slightest of mess. You really don't even have to clean it off as it usually just evaporates on it's own. But wiping down afterwards is a nice thing to do.
Sent from my SCH-I510 using Tapatalk
Wilson
South Dakota
so you still liking the mod am thinking about it but don't yet know why I jump and am thinking it will help but have yet to bottom out other than slightly. do you jump and dos it help? also if it is made adjustable is every thing still under warranty I've been looking at this on the forum but most go top for me am liking the mid.
Wilson
South Dakota
question do you do the back and front or just front or can you do both I should just go look at the back ones have yet to really look stuff over.
Phyguy
Denver, CO
No jumps. Yet. But, just the stance alone is worth it. No more nose-down driving, nose-dipping into turns, etc. Feels like it should in some odd way. I'll get profile pictures shortly.
---------- Post added at 08:38 AM ---------- Previous post was at 08:35 AM ----------
I had them install the stainless, braided brake lines at the same time they were doing the perch. Is that what you mean? 290 out the door for installing customer provided brakes lines, flushing with DOT4 blue and perch mod.
