Perch Mod Discussion
Mid perch or no?
  • Total voters
    426
5150_Raptor
Can I fit 37s at mid perch? Searched but can't find, I'm also on my phone
Sent from my SM-G930V using Tapatalk
Aaron
Meme Corps Commandant
WA
Yeah you can. YMMV on rubbing depending on the tire. Consensus is 37x12.50 BFG ATs fit best as they are smaller by a little. I'm running 37x12.50 Baja TAs with no rubbing on stock wheels.
FordraptorHero
Well-Known Member
anyone here in phoenix able to adjust my shocks?
looking to get my shocks adjusted to mid perch in the phoenix area, contact me if you can for a reasonable price.
40oz
Sorry for not reading all 156 pages of this topic...but if you go mid perch, and you have the flutter stack mod...is the ride quality similar to bottom perch?
Raptized
Raptorida
I screwed up and used the box end of a ratcheting wrench and now it's stuck in the the coil. Any suggestions?
Sent from my SAMSUNG-SM-N900A using Tapatalk
---------- Post added at 09:02 PM ---------- Previous post was at 08:59 PM ----------
Raptoe13
Chickasha, OK
Tighten it back down until you can remove the wrench. Might have to tighten both spring compressors to get the job done. BTW, you're not alone. I've done the same thing g.
Sent from my SM-G955U using Tapatalk
Raptized
Raptorida
Tried it 2 dozen times and nothing. Used ratchet straps and breaker bars and tried to move spring to no avail. Just tried to saw the wrench and dulled all my blades. *****.
Raptized
Raptorida
Well I used the rachet strap in the closed end of the wrench and tightened it as far as I could and it was just enough. Whew. Next side up. Lesson learned.
Done! And I gained almost 2 inches with mod!
rkneeshaw
Northern Michigan
Today must be bad luck for people doing this mod. I had a hell of a time.
I ended up removing the entire strut assembly because it turned out to be quicker and easier than fiddling with those damn compressors. Its only three more nuts (strut, tie rod, upper knuckle) and you can get it out.
