Perch adjustment as quoted by lcl dealership
superduty
superduty
LA/MS
That's what my dealership quoted me also. I found a local auto accessories shop that did it for 235 including alignment.
pirate air
will plunder your booty
Torque spec is correct. The bolt is steel. It is also advised to replace that bolt and nut, the tie rod nut, upper ball joint nut, and the upper shock absorber mount nuts.
Deinonychus
Jacksonville, FL
I had mine done at a shop that specializes on trucks while I was at work (They also installed my RPG steering tie rods at this time).
They got a late start.
When I was dropped off at the shop from work they were just stating the first perch adjustment (it was in their spring compressor). While in it looked pretty straight forward.
But putting it back in the truck looked like a pain in the ass. I would not have wanted to mess with that (I would be doing it without another set of hands, which looked like it would be a great help).
I was there while the entire work was done on the other side. That took about 20 minutes. This side went back in easier than the first side.
My bill was 3 hours labor ($70/hr) plus a $70 alignment charge. [included tie rod installation]
NickPic83
Rockland County NY
thought about doing it myself but a custom shop not far from me will do it $250 w/ alignment. for that price ill have them do it and hang out and check out all the cool projects around the shop
Aaron
Meme Corps Commandant
WA
Too bad most of you guys aren't closer to me :)
No kidding, he hooked me up with a great deal on mine.
SOCOM, you should go check out those trails over on 163rd, There's an entrance off the 74. If you want the location of the entrance let me know and I'll shoot it over. It's a great place to take the truck out that's nice and close.
