daddycreswell
Seems I'm only one reading this, but anyways. I did the mod tonight, I learned before hand that if you just do the yellow wire with blue tracer in the grey 10 pin connector you are only going to have the front parking lights on. I wanted the back on as well, so I did some googling and found out that the rears are in the black 32 pin connector with the clip on it the wire is yellow with green tracer. I used 2 pieces of wire, used the side by side connectors (don't know what they are called) tied into each of the parking light wires and then into one wire going into the AUX 4 wire which is brown. Took me about 30 minutes and bam I was done. One note, if you pull that black 32 pin connector out and you will need to your inside lights will flash until you hook it back up so don't be alarmed when it happens.
