Painted the beadlock rings for my 2013 Screw.....l
DynoDynge
Zavalla, TX
I really like that light bar, now that I've seen one mounted the right way!
I had a customer come into my shop & a local custom truck shop had mounted his backwards (with the light directly above the moonroof):idiot:
iSurvive
Highlands Ranch, CO
iSurvive.....that truck is bad ass. Where did you get your light bar above your windshield?
Thanks! The light bar is a RIGID 50" Flood/Spot Combo LED. The brackets are also RIGID. RIGID Industries. Retail $1,599 LED and $285 brackets. You can shop around and probably find some deals.
The install is a pain in the butt!! Worth it though!
ffghr356
Painted rings
How did you remove the rings? Can you remove the rings keeping air in the tires? Or do you have to park the truck while the rings are getting painted?
Thanks
Installed the painted rings......I really like the way they look now. Paintshop did an excellent job of matching colors. Before, the silver rings stood out since nothing else was silver on the truck. I also put a thin nylon washer behind each Torx screw when reinstalling the rings.
Before:
After:
BAJASVT
SE Michigan
Thanks
These wheels are capable of being converted to true beadlocks with the Ford Racing rings (part # M-1021-F15RA), but in stock configuration the rings are just decorative. Yes, you can remove them and still drive the truck.
BobbyVA
Northern VA
Do you know of any aftermarket rings that come in different colors or do you just have to have them painted?
Got a 14 tuxedo blk on the way and want to get rid of that silver ring and paint and or replace it with blk...
DoingOK
Smithfield, VA
I doubt any aftermarket rings have the same bolt pattern or fitment as the factory ones. Easy to just remove and have painted.
crashmc302
Idaho
I'm pretty sure the bead lock rings have a 24 bolt pattern and the street rings have a 12. I saw something that explained this on youtube a couple hours ago. DoingOK had the same idea as me, I just took my time about it. After seeing his results, I think I'm still gonna have em painted and maybe even set them up w beadlocks and 37's (along w all the other mods that go with it) sometime in the future.
Edit: http://youtu.be/on7dSpsmF-w
Hopefully this is a good link for that video.
Stang
Rings look good. I think what would also look good is if you sprayed your orange mirror reflectors the same blue.
Sent from my SCH-I545 using Tapatalk
