from the relay trigger connection? that much?
Yes, and most draw more than that.
What about the low beam circuit though? Specifically, some of the F150s besides the Rap are wired for factory fogs. If I’m not mistaken, the wiring is still present on the Rap. Someone asked many moons ago if we could simply drop in an F150 headlight switch with fogs, and connect up some lights - saving 1 of the up fitter switches. I don’t know that anyone ever did it. But, that circuit should be an option - Fogs are permitted with low beams and turned off with high beams. it wouldn’t be the most elegant solution but
-could you safely use that as an option to relay in some after market lights? In other words, instead of the factory fog lights, have that setting trigger a relay or even just some rigid or B/D SAE lights?
Interesting idea, especially if you can use Forscan to enable the fogs and the fogs are controlled by the BCM. You should be able to do this safely if you can figure out how much current the stock fog lights draw. Choose a relay that draws that much or choose fog lights that draw that much.
OK, I went searching and found the diagram that @FordTechOne posted earlier.
I don't see fog lights, but this may just be showing the connection between the BCM and the headlight assembly. We need to know if the fogs are driven the same way. @FordTechOne ?
So.... if we keep it reasonable, that might be an alternative. complicated but more viable and at least potentially safer than high beam trigger.
