OriginalToken
- Joined
- Apr 17, 2018
- Posts
- 180
- Reaction score
- 155
Howdy all,
This week I am going to start installing radio gear in my 2018 SCREW. 3 radios to start with (2M/70cm, HF+6M, and BCD536HP scanner) with probably more coming.
I like clean, out of sight, installs, with no visible cables and preferably the control heads out of sight until needed. So the VHF/UHF control head will go in the sunglass holder in the overhead, it can be flipped up and closed. The HF+6M radio will go in the closable pocket at the front of the flow through console. Both of these radios will be mounted on a board under the back seat. The scanner will be in the console compartment, mounted vertically on the front wall. Speakers will be mounted either under the seats or in the side pockets of the console. Microphones will be mounted to the inside sides of the console compartment.
VHF/UHF antennas and scanner antenna will go on the light tray of the sport bar, which can be layed down electrically (using upfitter switches). The HF antenna will be mounted so the top of the coil is at roof top level, and the whip section can be removed. This allows everything to be stored lower than the tip of the stock AM/FM antenna if needed, such as for drive through or parking structures.
But in order to run all the wiring I will have to take the interior apart quite a bit. Remove A piller covers, lift up center console, get under carpet, etc. Is there a good resource with pictures or drawings showing these parts and how to remove / dismantle them?
Of course, it ain't rocket science, so it should not be hard, but it is always nice to know about that hidden clip before you start prying on a plastic panel.
Thanks,
T!
Thanks,
T!
