Onboard Air Compressor Install (pics)
Frank N
NJ and Outerbanks
The two places I always air down has filling stations but I have a single ARB I keep under the back seat for emergencies.
I will say to those looking to mount, I'd recommend the double, the couple of times I have needed to use the single, it gets smoking hot taking 4 tires from 18 up to 35 PSI.
Jonesy_PNW
Oregon
Another excellent solution I am going to try is to put it inside my Tuffy rear underseat lockbox. Dimensionally I haven't checked to see if it will fit but by the looks of it it should be no problem. It will be secured, locked, and dry.
The Car Stereo Company
here, on frf
Sorry to bump an old thread. Has anyone else installed a deal ARB into their Raptors?
this is what you are supposed to do. you searched and found a thread instead of posting a new thread with the same questions. doesnt happen often, but good to see some people look first.
as far as your question of onboard air, i think you found some answers
jbishop98
West of the Mississippi
Sent from my iPad using Tapatalk Pro
I like this. How did you mount it?
hahahaha! Thanks. I've been around car forums for a while. I try to use the Search feature as much as possible but you know some search engines are just pure garbage.
manny
San Jose Ca
1” x 1/4” flat bar crossing from seat bolt to seat bolt and mounted compressors to the bar
here, on frf
Thank you! Any pics of said bar? Also, did you wire it to the uplifter switches? If that's even possible. I forget the max amps per switch.
i think its wired to a switch right by the compressor. been so long since we installed it. as far as an aux switch, you just have to use a relay to wire it in.
