On board air compressor?
Thomas_JohnDoe
Chicago
Whoa more than the twin itself. It’s a clean set up, I ended up putting inside the cab since I hadn’t heard from you and needed it up and running for Moab. Yes,
I would want one. SDHQ would be a good start. Since buying my set up, there have been companies I’d stay away from. Could just have your side gig. I’d def promote it on my IG. I see it fitting all the 09-14 F series.
can you post some pictures of where you mounted it
Raptorlander
Fort Worth
Here you go. Technically didn’t mount it to anything it’s just sitting in that area. Wired it to my Aux 4 Switch. Just got a Decked and debating on putting it in one of those ammo cans.
ImAllSCREWdUp
PG Co. MD
Here is an install I finished up a few weeks ago. Second truck I have setup with onboard air — definitely worth it. The ARB compressor doesn’t disappoint and check Swarfworks for the air tank frame mount. Paul’s products are top notch.
View attachment 321460View attachment 321461View attachment 321462View attachment 321463View attachment 321464
@sj-CHI Beautiful set-up. Im planning on doing something similar. How did you mount the compressor on the molle panel? How did you reach the bolts to thread into the compressor back-plate?
BTW, the under-bed air-tank mounting plates are back in-stock at Swarfworks. Ive ordered mine.
