GEN 2 On board air compressor and tank install
Jakenbake
Have the same compressor mounted in the bed and have had issue with the relays rusting out. Water in the air compressor. Don't recommend mounting under the truck
I assuming you are talking about the ARB twin? If so I am considering remote mounting the two air intakes up under the bed rail bed hind the builtright bed racks to help with keeping them away from the elements a bit more.
On the relays did you replace them with a more weather resistant relay or factory?
I am likely going to switch to a vertical tire carrier/bypass rack which then I’ll need to permanently remove my bed cover.
mxsk8srf
Florida
@ShadowRaptor where did you get that molle style mounting plate? I'm thinking about doing this myself in my pending overland build. do you need the additional batteries to run this set-up, or is the stock battery config good enough? did you wire to an accessory switch in the cab?
