Ok some one do a zero to 60 time
BambiKiller
The Stripper Hunter
Oregon
IMO My GooseTune E50 tune hauls on the top end big time and I am waiting to run into a TRX. I am sure out of the hole the TRX would get me due to launch control but top end I would walk right past it. I need to purchase a Dragy and get some numbers.
I’m down for a draggy comparison. I only have a lower pulley pushing 12psi and can test between 1250-2500ft in elevation.
BambiKiller
The Stripper Hunter
Oregon
@10SpdsOfFury just ordered a dragy. Be here Friday or over the weekend. Whats your elevation? I’m in SW Oregon. Here are my projected temps. If anyone is nearby and wants to run let me know. I’m in bfe but closest town is Medford
BambiKiller
The Stripper Hunter
Oregon
@BambiKiller
16ft Jacksonville FL. I just ordered straight from Dragy so probably here mid week.
Lol. 16ft. Careful or tHe GLobAl WaRmiNg will get you when the oceans take over.
Ok. I’ll get as low as I can but it’s probably max 1200ft. Never had a dragy. Assume it will do intervals also? I don’t have a tune so hit the limiter at 117 but would be interesting to see 30-100 and 60-100 or 110.
10SpdsOfFury
Jacksonville FL
The Dragy is spot on with the drag strip so I have read so it should be a fun comparison.
Found this screen shot which shows some of the stats you can record.
BambiKiller
The Stripper Hunter
Oregon
Nice. What mods are you running? Approximate hp/tq? Or have a dyno chart? This is going to be fun. Think we could start a virtual race thread without it getting screwed up by fanboy hate(either side)?
Johnkn
LaPlata, MD
When going 0 to whatever in a Raptor, is 2H with TC off the best mode?
Edit, sorry, meant 4H with TC off....
BambiKiller
The Stripper Hunter
Oregon
Depends if you are getting wheelspin to any significant degree. If I was getting solid grip I’d probably run it 2h with tc off. Kinda depends how intrusive the tc system is. If you get a lot of wheelspin try it in 4h and whatever setting gives you enough suspension squat to load the rears. In the trx its the baja suspension setting that seems to work best on launch. It’s a 70/30 split
Johnkn
LaPlata, MD
Darned, sorry, I meant 4H with TC off for a tuned Raptor. Mine will roast the tires in 2H with TC off either just stabbing it at idle or braking against the converter.
10SpdsOfFury
Jacksonville FL
I have Whipple charge air cooler and Cobb CAI with Cobb AP with Goose 93 and E50.
I went to the dyno on a hot day and went right on rollers but the guy wasn’t there and his wife made the runs. The HP/TQ didn’t cross on the graph at 5250 like it’s supposed to so not sure if it was accurate or not, dyno said 460@504tq.
Sport mode in 4A is best and as soon as you hit 2nd turn the knob back to 2H. I try and build the boost up on the brake and let it rip.
