ok mall / street rats.....what millage are you without doing the shock rebuild?
nikhsub1
Los Angeles
If the shocks(dampers) are not leaking and you’re not noticing a problem, why would you rebuild them?
I'm guessing cuz the manual says to... on another note I have the non live valve 3.0s - does anyone know of a place that does rebuild swaps with those?
tooloud10
Iowa
This is the kind of thing you have to take with a huge grain of salt. My truck is mostly street driven, I'm around 55k miles, and I can't imagine paying to have the shocks rebuilt simply because they manual says to do it at 50k.
I'll do it when they leak or I notice that they're worn out, just like how I replace tires when they're worn out and not at a specific mileage.
thatJeepguy
GA
Money and time, the same things you gain by not paying for anything unnecessary.
Yes but think about it like this, you service them now and you can roll to 100k …
What happens to a shock is the fluid loses viscosity due to heat cycling and absorption of minute amounts of moisture which cause emulsification of the hydrolic fluid. Also the seals wear and trim specs on tolerance come out of spec. Stroke volume and dampening change and I assume the live wire system will compensate by going to the firmest setting.
goblues38
goblues38
STL
This is my exact thinking
goblues38
goblues38
STL
It’s a shock. When it goes bad. I think I’ll replace it. And save some cash. Why replace it at 50k if it will go to 75k
Tbogo
TX
There are a lot of Raptors out there and I'll bet most folks are NOT rebuilding their shocks at the Fox or Ford recommended intervals. Probably only the heavy off-roaders are doing theirs and usualy because they are leaking.
