Oily Spark Plugs?
Dirtsmith
Salt lake City
Searched before posting... How common is it to find minor oil fouling and oil on the threads of the lower 8 plugs and should i be concerned about rings at 152k already? all lower 8 had oil on them, the upper 8 did not. these are original plugs as far as i can tell.
Gumby
Nashville
Searched before posting... How common is it to find oil on the threads of the lower 8 plugs and should i be concerned about rings at 152k already? all lower 8 had oil on them, the upper 8 did not.
Did you find this????
Dirtsmith
Salt lake City
Sure didnt right until i posted this and it was the first similar thread. his thread doesnt really help answer my question though.
Gumby
Nashville
IMO..... The lower plug are not the work horse plug. more a clean up plug. Are you using/loosing oil between changes? if so how much? if not.... why would you suspect rings? this is engine with 150k on it. mine has 195K I would not be alarmed if I saw a little oil on the thread portion of the plug. With that said I have Not done my plugs Yet. They were done at 120K. I do plan on doing them soon if I find a little oil on them and the truck runs as it should. I am not going to leak it down and compression test, bore scope. To chase a problem that is not really there. Because it used a pint of oil in 5000 miles.
Dirtsmith
Salt lake City
Just bought the truck so i haven't had time to figure out consumption issues. Plugs hadn't been done, coils were so bad they were unsalvageable on a California truck which was wild.
MTF
Celebration, Florida
If a vehicle wasn't properly maintained, it doesn't matter where it came from!
I would switch engine oil up to W5-30:
