JohnyPython
I don’t find it that bad to access the oil filter. Relocation is just one more layer to deal with, IMO. I’d rather spend the $ on bourbon.
I think plastic oil pan tho.The 2.7 Eco Boost has the filter on top. That would be convenient.
Sam
That’s at the sensor. If you’re under boost you might be getting some extra pressure from somewhere else under constant throttle.the computer already drops the oil pressure randomly anyway.
watch it on an obd2 guage. stupid variable pressure computer-controlled pump will drop oil pressure below 20psi under constant throttle.
you might, but you aren't.That’s at the sensor. If you’re under boost you might be getting some extra pressure from somewhere else under constant throttle.
the upgraded timing components are also 6K. essentially you can swap the entirety of the Ford GT timing componentry onto a raptor, but its all or nothing. ( i.e. you cant just use the Ford GT chain guides, you have to do the whole banana)good to know. I was just guessing
