Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
im using Mobil 1 synthetic and motorcraft 820s oil filter. I will dab some oil on the rubber gasket but not fill it with oil since it does install horizontally
To add to whatever one else says ... I always put oil on the filter threads too. Probably doesn't matter but since the gasket is getting it might as well lube up the threads while your there. Ol' man taught me that and it stuck.
