MTUH3
I should have said, or lack there of...
So this has me thinking hypothetically here...
In the last week I have thrown 2 engine codes
1. P0296 - Post Catalyst O2 sensor Lean
2. P216A - Imbalance Air to Fuel Ratio
So far I have taken measures to resolve both codes by replacing the air filter (P0296) and cleaning the MAF Sensor (P216A).
We will see if the codes, or different ones return over the next week, but there is the possibility that the Catalysts are going bad and clogging. I could just replace the Catalysts, I could go with "high flow" catalysts, or upgrade to a combination of headers and catalysts or headers and no catalysts. (Clogging catalyst may be trapping more fuel particles, which may have thrown the P0296 and also affected the P216A as the ECU is assuming the A/F is off because it is not getting a good read on the O2 sensor.
I would prefer the last option, because of cost and no catalyst I would assume still flows better than a high flow catalyst.
Here is the trick: And this is where the post goes more into the Engine category.
1. I am in MI. No inspections.... yet... so I am clear there
2. I don't want to stare at a check engine light all the time. Can the flag be erased or fooled?
3. Even if I can fool the O2 sensors, the engine does still use that information to tune itself on the fly, what might be the impacts if I feed the ECU a dummy O2 reading vs an accurate one?
Corallary: Do the O2 sensors need the catalyst to function properly, or can they still perform their task without?
