All lights in! Here’s the driver’s side:
Doing the wiring now...ridiculously easy with the plug and play loom pre-made for 2xBD 2” cubes (Squadron) and 1xKC Flex light that I picked up separately.
I went with the flex light with the optional amber covers because I wanted a lower wattage marker light I could run all the time as a DRL and as a low(er) power fog light without getting flashed all the time.
Center light is a BD Pro wide cornering, and inboard lights are BD Pro spots. BTW, it took an extra “thick” washer on my particular BD lights to perfectly center them vertically in the bezels. Looks awesome though...this should be how these trucks come from the factory!
Will install the XLs on the A-pillar mounts tomorrow...will cover that in a different thread to keep the non-FRL “noise” to a minimum!
Just to confirm, these lights need a separate ground. Correct?
Loom has the three hot wires I’m about to wire into my upfitter switches, as well as a black wire that is merged from all 6 lights. I assume this is the ground.
