GEN 2 OEM Genuine Ford Parts Scalable Shock Security System Kit
SOAKINRED
SOAKINRED
Orange County CA
802
interesting as I just looked at my window sticker I have the 802 package and it lists Perimeter Alarm, wondering if it's the same thing.
Anyone have the install documents so I can figure out where it might be.
Yes the 802 comes with a alarm that has sensors in the inside of the truck, this part is for the out side of the truck and is just a add on, sock sensor, like if someone hits your truck or breaks a window, excreta.
TheProcessoperator
How sensitive can you make the shock sensor? Sensitive enough to alarm on a soft pull of a door handle? (Bad kids in neighborhood opening car doors at night).
SOAKINRED
SOAKINRED
Orange County CA
BajaMod Alarm Shock Sensor Bracket
I bought one of these today, I know i could make one but this was already done.
Fits Ford Part: FT4Z-19A361-A Perimeter Plus
Product details
An Aluminum bracket that holds the FT4Z-19A361-A Perimeter Plus alarm upgrade for your 2017 Ford Raptor. Rather than using the supplied zipties, this allows you to bolt the shock/impact sensor to existing bolts under your dash. Comes with all of the necessary hardware. No drilling necessary. Made in the USA.
BajaMod
HulkSmash23
MN
I have mine mounted on the bracket and bracket installed. Where exactly to I plug it into? Pics? Does the lower dash panel need to be removed?
hmgt3
After installing my shock sensor I've noticed that remote start doesn't work anymore. Anything I need to do to Re-enable it ?? Has anyone experienced that before?
Sent from my G8142 using Tapatalk
SOAKINRED
SOAKINRED
Orange County CA
Remote start
Disconnect the battery for 5 minutes and try it, mine did the same thing and has worked perfect ever since.
---------- Post added at 12:47 PM ---------- Previous post was at 12:45 PM ----------
Well OK it can get really sensitive, the adjustment is very easy also.
