Observation regarding the shifter stock...
rayw1128
Hi all,
Just took delivery of the 2018 Raptor. Read the manual and tried to study how everything functions.
One thing I realized about the shifter stock... there are no indicator by the shift stock to tell you which shift you are in (I.e. Park, reverse, neutral or manual).
I understand that there is an indicator in the dash, but just find it to be awkward (for me at least, that there isn't one by the shifter)... I find myself always shifting into M when I want to go to Drive and having to double check in the dash all the time.
Does anyone else have this problem?
Mjolnir
Colleyville, Texas
Hi all,
after a couple of days your hand will build a memory of where D is. not to worry.
Ltl6pack
Cheraw SC
Hi all,
My 2017 has the P,R,N,D & M beside the shifter. Not sure about the 18. It lights up to show what position you have it in.
BurnOut
I just squeeze the detent long enough to get it out of park, then pull straight back and let it stop on its own (in Drive). I don't physically squeeze the detent the whole time. You can move R-N-D (in that order) without having to squeeze the detent.
Mistacheese
Ontario Canada
What burnout said. Let go of detent as soon as you start moving the shifter. It stops automatically at D and wont go into M until you press detent again.
Helopilot
Northern MN
Both of our 18’s have the illuminated shifter position indicator on the drivers side next to the bottom of the shift lever.
