No Washer Fluid Sending Unit?!?
AndyR
The Mrs. (VW v10 TDI Touareg) has a washer fluid low warning light and associated beep. It's so annoying that one of these days it's going to have an accident with a pair of side cutters.
MagicMtnDan
Magic Mountain
How do you like that V10 TDI? I was fascinated by that monster torque-ster and disappointed they killed it not long after they introduced it.
AndyR
It's pretty awesome, stump pulling torque - just eats the miles. Has a rear locker and almost 12" of ground clearance with the suspension set on high. She has a set of street tires and 2nd set for the desert. What *I* want is the V12 Audi TDi - now that would be a great commute car. It was killed, then re-introduced for one year (2006) which is what we have, then killed again in CA.
gordhunt
I thought it was lame it didn't have one but not a big deal
Sent from my Galaxy Nexus using Tapatalk
HoustonRider
the Raptor is definitely not a work truck.
and I can't remember the last time I had a car/truck that did NOT have a "low washer fluid" light.
ISFast
Tulsa, OK
I was shocked it didn't come with one! Now that I know I don't have one not as big of a deal i just have to old school check it but the first time running out when I needed it wasn't cool. It also had just came back from the dealer for an oil change so...
jdowens1
Ford Senior Master Technician
Montana
I'm not 100% positive but some Ford models I think have low washer fluid light. I think the Lincoln models do. I think Ford used low coolant light and washer light at one time previously in past but they were nothing but problematic. Same reason there oil pressure gauge is just a dummy gauge.
ISFast
Tulsa, OK
Do you happen to know what range the dummy gauges scan from? like oil PSI 0-100 and is it linear? Also what about the tranny temp gauge. The 2010's you can't actually see the temp just the gauge with no numbers. Thanks
