No tail lights
GRI
ny
I noticed that I have no tail lights this morning . The weird thing is the small marker lights aren't working either . If one of the bulbs are out would they all be out? I don't think so, but before I start checking wires fuses I wanted to check.
Is this a common failure?
sent from one of those damn cellularized telephones
NickPic83
Rockland County NY
Never heard of this happening. Probably a fuse but the question is what caused it to blow...
Sent from my DROID RAZR using Tapatalk 2
G
GRI
ny
Yeah, very weird. I have brake and reverse lights. But no tail lights. I am going to check my front parking lights now. Didn't think to check those. If they're out than I know its a fuse
Fred
Richmond, VA
Did you replace any of your running lights recently with LEDS or anything else for that matter...I know we have had a lot of folks getting LED replacements...
And yes if a fuse than why?
Good luck?
G
GRI
ny
No parking/running lights at all. I replaced my reverse lights but they're working . I added fog lights and 4 kc lights to the upfitter switches. Looked in my owners manual for the fuse location. But the fuse box is different than the diagram in the book. Anyone know the fuse#
CoronaRaptor
CANADA
Drive by a ford dealer and get a new fuse, if it blows again then I would worry, otherwise things happen, could be moisture on the fuse, a bug, some dust, doesn't take much to overheat or short out a fuse. They are designed that way. Quick-acting fuses!
G
GRI
ny
Anyone know the fuse number?
G
GRI
ny
No just numbers
Fred
Richmond, VA
No just numbers
I know you said it did not, but the numbers should correlate with the book..
Did you try to "google" the information or call your parts dept?
Fred
