Ok guys. Dawson @
Raptor Retrofit really hit this one out of the park! Boom!
If you where at snoball, you got to see these bad boys in person.
I feel like a little kid on Christmas morning when I fire these flaming heads into action.
The Osram CBI bulbs are so worth the upgrade! When I click the high beams on they light the road on fire in front of me. My previous MH1 build was bright, but when going to the high beams, The light never got brighter. It simply lifted the projector bulb cut off. The FX-R with Osram CBI bulbs are so unbelievably bright and have a great flood pattern to the sides that I can change my light set up on the front off the truck.
The laser etch, evil eye and green back lit give this build such a unique quality that only a Night Raptor can pull it off. I wired the "bling" lighting to an aux switch and also tied in some blue LEDs for the side vents. As some may know, the amber rings can have a limited life span. I've read that it can be due to running the amber rings and the projector at the same time. Thus is why I used the aux switch instead of the tap into the amber marker lights.
I am very impressed with the output of these lights. Having the ballast mounted directly to the back of the head is also a nice new feature. Makes installation a lot easier.
Dawson - thank you for your donation to the Be The Match raffle at GLRE's Havoc in the Hills. And thank you for a great set of heads!
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
