New Wheels
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
OK - wheels mounted - that was a lot of work. Any help on tire pressure is appreciated. Here is preview until I find a good place to take some pictures....
I usually run 40psi on the street and anywhere from 20psi-40psi offroad with my Grabbers.
SOCOMech
Famous Raptor
Phoenix AZ
Nice!!!!! Julian's and the Raptor R and XT are the only ones I've seen with the Enduro's. I was originally wanting them a long time ago but couldn't find any place that had the correct bolt pattern. You need to post the pics!
T
tnsbruce
OK - here are a couple pics. I need to do the front perch mod or cut my fender wells - I get a little rubbing when turning under compression.
I also have a slow leak on the secondary valve stem on 2 of the wheels - I need to figure our how to fix this. Is there anything better than plumbers tape to put on threads before installing?
I dropped about .4 mpg with the new wheels, braking takes more effort, and the transmission downshifts more frequently, but I think they look awesome!
RPG
Orange County
I dropper about .4 mpg with the new wheels, braking takes more effort, and the transmission downshifts more frequently, but I think they look awesome!
The second valve stem is for the inner liners and i had the exact same problem on my methods. You are going to need to let all the air out of the tire, remove the secondary valve stem and red lock tight it. Just do all four now because the others will start leaking. also, re-torque the bolts with the air out of the tires. After that, they should stay perfect.
The wheels and tires look great by the way...
xBX
What sizes did you go with?
T
tnsbruce
Thanks for the tips - I will get the secondary valve stems squared away today and re-torque everything.
Wheels are 17x9 with 0 offset, tires are 35x12.5x17
fordrap2010
???? what size did you get 17 x 8 WITH WHAT BACK SET 5 INCH ?? THAT WOULD SET THE WHEEL OUT 1/2 INCH ??
