Is the wrap blocking the drain holes on the lower portion of the doors? If so, it may cause water to fill up the doors.
Looking at the recall, it looks like the the only bolts that are replaced are the anchor bolts for the front seats, the four across the front,I don’t see where any bolts in the door that are replaced. It shouldn’t have anything to do with a water leak.
I agree that this should have been the case. I'm not sure if they assumed the seatbelt anchors needed to come off as well by mistake. When I got the truck back that panel had obviously been removed and not replaced correctly. The seal above the door was also hanging partially off and looked like it had been messed with. The indentation marks in the seals from where the doors close no longer line up.
They have the truck again and are fixing the seals and plastic panel. I hope that fixes the leak.
What's the build date on yours?
