NEW Smittybilt Overlander
RSiWORKS
S.C.S. Michigan
ALL NEW
Overlander Tent and Awning
There are few things more relaxing than jumping into your Jeep and getting away from the hustle of daily life. Smittybilt recognizes that you don’t have to leave all the creature comforts at home though, and their new line of Overlander gear can make your outdoor experience even more enjoyable.
Set up camp in minutes with Smittybilt’s OVERLANDER ROOF TOP TENT, with waterproof construction, mesh windows for ventilation, and a wide aluminum ladder as standard features.
Smittybilt Overlander Tent is designed to mount easily on your stock roof rack system or on an aftermarket rack/crossbar system. The Smittybilt Overlander Tent weights only 118 lbs, so it can be mounted to most rack systems. Generally, most OE roof racks will have a capacity of 100-200 lbs while vehicle is in motion(dynamic rating). However, when the vehicle is parked and you are utilizing your Smittybilt Overlander Tent, you are applying a static load which is easier to support and most rack systems can generally handle this static load with ease. Always check with the manufacturer of your vehicle and your roof rack system to determine the applicable weight limitations as they vary from vehicle to vehicle.
If you need a roof rack system or more carrying capacity you may check with your local supplier for Smittybilt, Thule, or Yakima racks to suit your needs.
Check local and state laws regarding roof mounted load capacities. Many states have a limit of 165lbs while vehicle is in motion, and therefore most vehicle manufactures will build their roof racks to meet that limit. The Smittybilt Overlander Tent weights only 118 lbs, so it can be mounted to most rack systems.
Built with the same high quality materials as their roof top tent, Smittybilt’s OVERLANDER AWNING provides shade on those hot summer days and easily attaches to most standard roof racks.
Contact RSIWORKS for more info and pricing.
:hitit:
