New Rear Suspension Set Up?
Raptor911
Ashburn, VA
Not to derail this thread but are you running stock shocks front and rear? How do you like your setup with deavers+2 and the ICON bump stops?
So I currently have the ICON bump stops and Deavers +2. So their new set up would just require their new rear shocks? Or special leafs as well?
BABaracus
Los Angeles, CA
I am currently stock shocks all around (mid perch). The change to Deavers was fantastic! As far as the bump stops, well my frame seems straight so it must be working. Since I'm relatively new to this I've had my good share of oops moments while off-roading.
If it turns out that the new set up works well I would upgrade to 3.0s up front as well as these new rears since I have the ICON bumps.
---------- Post added at 12:32 AM ---------- Previous post was at 12:31 AM ----------
Jack what is WCPR?
jackrook
Bermuda Dunes, Ca
I am currently stock shocks all around (mid perch). The change to Deavers was fantastic! As far as the bump stops, well my frame seems straight so it must be working. Since I'm relatively new to this I've had my good share of oops moments while off-roading. If it turns out that the new set up works well I would upgrade to 3.0s up front as well as these new rears since I have the ICON bumps. ---------- Post added at 12:32 AM ---------- Previous post was at 12:31 AM ---------- Jack what is WCPR?
Local group of hooligans/Raptor owners I take the truck out with. Everyone has 3.0s and aftermarket this and that. And me with just my bump stops LOL
slowest member of WCPR
CrownOffroad
San Diego, CA
Spotted this on Instagram today. Between this and Birdman's picture the new Icon rear set up seems to be getting closer to actual production. Now will this work with Deaver/National +2 or +3 springs? What about those that have the existing Icon bump setup? Looking forward to more details on this setup.
RLTW
TX
I can vouch that this set up fuggin hauls offroad, I rode with bird at havoc and it was a blast. The leafs are suppose to be out in the next week or two and the shocks a week or two after that, they said by October end. I'm buying.
It does work with existing icon bumps, that is what the little spacer was for when you installed them, they had this rear shock setup in mind. I can' speak for use with other leaf springs.
ntm
Alberta, Canada
Hopefully these Fox junkies will realize that Icon is an equal alternative.
I'm still happy as heck with my icon 3.0 bypasses.
They've proven to be very reliable and perform very well, better the fox 3.0 bypasses I believe.
Their coilovers are a different story though, the fox 3.0 coilovers best them soundly.
vanilla_gorilla
NorCal (Sacramento)
So what you are saying is that people wanting 3.0s should run FOX up front and ICON out back? I often wondered if mixing and matching would be a good idea.
MTUH3
Plymouth, MI
I have Icons in the front and Fox's in the rear. Mixing and matching does not seem to be a big deal.
I will say I would prefer the Icon fronts over the Fox fronts. I rode in a couple trucks with Fox fronts, and it was too soft for my liking. I am really happy with the feedback and response I get with the Icon fronts.
RLTW
TX
I'm definitely prefer icon fronts, I don't want my front end swaying around sloppily.
