New product!!! Abs sensor shield
Mesa, AZ
New product!!! Abs sensor shield.
Hey Everyone. We are aware of the issue with the ABS sensor problem with them breaking and with them simply located in a bad spot. With the $500 cost to fix it when they break, I thought it would be a lot easier to build a protective shield.
The pics are crappy but it will give you an idea of how it works.
Simple 1 bolt install.
Shaggy
Administrator
Staff member
Admin
Arizona
Nice little addition. I say the post with BigJ and this looks like it will protect it from not breaking as easily.
Addictive Desert Designs
Mesa, AZ
Ok everyone they are ready to order. We made a few changes with a better tab and a higher quality tube. They are super easy to install and bolt right on.
We also include a grade 10 bolt which is a huge step from the factory grade 5 bolt.
They are powder coated and ready be ordered. I will have good pics up later.
It is $50 for the 2 rear gaurds and 2 new bolts shipped anywhere in the U.S
P.M. me for orders or give me a call.
Thanks
Mesa, AZ
This Protector gives you 360 degrees of protection around your ABS Cable and sensor. The front of the trucks abs cable is not exposed so there is no need for the front ABS cable protector.
Mesa, AZ
Here are some install pics, Takes about 5 min total.
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
Just installed them in under 5 minutes, easy as pie.
Thanks for the C.Y.A., A.D.D.
Fellas, all you nedd to slap these on is a 10mm socket to remove the existing bolt, feed the guard sleeve on around the sensor, and use a 6mm alan wrench to tighten the new bolt, rinse and repeat. Boom. Done.
