so you will probably want to wire the compressor to a switch or to ignition. (as long as it has a psi cut off) that will allow the tank to fill and then automatically shut off the compressor.
You want to wire it to an ignition switch with a 15 amp fuse. You want the compressor to run only when the truck is running.
Yukon Joe![]()
thanks for info
get original part on amazon.com
I wired mine like this:
upfitter to 85 or 86, doesn't matter. also powers to pressure switch
the other (85 or 86) to ground.
Built a breakout harness to plug in horn harness
power from horn relay to 30
OEM horn to 87b
Train horn solenoid to 87.
The connector for the horn side is WPT-1193
The connector for the body harness is WPT-1051
the body of the horn WPT-1193 was just a hair too long to lock so I sanded it down slightly.
You also need a 5 pin relay, I see in your pic you have a 4 pin.
