NEED HELP ASAP, hooking up my amp remote wire to Aux switch 4
The Car Stereo Company
here, on frf
2010 ford f 150 accessory wire
purple/green at the ignition harness grey 10pin plug pin 5
2011 and 2012 ford f150 accessory wire
purple/green at the ignition harness black 7 pin plug pin 6
i dont know if this link will work because it uses my password
https://www.directechs.com/timages/acc_26349.jpg
---------- Post added at 03:18 PM ---------- Previous post was at 03:17 PM ----------
it looks like it did. here is for the 2010
https://www.directechs.com/timages/acc_25015.jpg
V
vosschs
Sweet, and this is right behind the glove box? I just need to wrap the remote wire around the Purple/Green wire right? I have a 2012
here, on frf
unfortunately not. this is at the steering wheel but its easy to run the wire to there. it should only take a minute or 2
V
vosschs
Ahh ok. It's easy to get too. So I just need to pull out the purple/green wire then wrap the remote around it and push it back in right?
here, on frf
sorry 6 hour drive from my house to reno....for a turn on for a amp or anything that is low current you can use a t tap or cut the insulation and solder to it, or a butt connector. it really doesnt matter as long as it doesnt come out
V
vosschs
Good deal. Thanks!!!
SwampKing
I read on another thread. I'm wiring my amp today but I'll be going to the passenger fuse box. Doing a simple "add-a-fuse" in fuse #38 which is the accessory fuse if I'm not mistaken
Sent from my iPhone5 using Tapatalk
here, on frf
vosschs- did you ever get around to connecting that wire?
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
swampking-those add a fuse can spread out the contacts, so if you ever take it out the fuse might be loose
95,829
59,528
mountain back
Latest posts
