nav-tv front camera/vim bypass
Reptar
Jersey
Just finished installing in my 2013. Everything appears to work great. I can confirm that the blue guide lines are not available when you force the front camera, but they do return when you meet all the original requirements for it to enable.
Is that a 2013 only thing or an update to navtv because they don't work on my 12
Sent from my SM-P600 using Tapatalk
The Car Stereo Company
here, on frf
Noah,
I'm planning on installing this Saturday. I believe we need 2 wires (for the front cam) that didn't come with the kit (or at least they are not long enough to reach). What length and gauge/type do you recomend?
18ga wire is fine. this is a data signal so it is not a high current wire. no need for a thick set of wires.
---------- Post added at 01:00 AM ---------- Previous post was at 12:59 AM ----------
i might add, i used 18ga speaker wire for mine. because the speaker wire is molded together as a pair, it made it easier to run. just remember which wire is which.
---------- Post added at 01:02 AM ---------- Previous post was at 01:00 AM ----------
not sure on this. i cant remember well enough. we need some 2012 guys to chime in
BGCPrez
So Cal
Great thanks Guys!
BGCPrez
So Cal
Im in the middle of my install and everything is great so far. Things were not this easy when i did this in my late teens early twenties but that may be because of my experience and patience or the vast amount of proper tools i have acquired through the years.
One issue; as i ran the cables through the firewall i discovered a cut line under the hood. See the picture below you can even see the black electrical tape beyond that appears to be detached. Anyone else have this or know what it is? Is it supposed to be cut?
Raw Horsepower
Santa Barbara, CA
I'll check mine, but I never noticed any.
BGCPrez
So Cal
Here is a better pic its on the right side.
