Narrowband Air/Fuel Ratio Gauge
KYmxracer52
S. Central KY
Here’s what mine looks like. I didn’t have it showing afr for this pic. Works very well. You can monitor a lot of different things with it and have the display rotate through several parameters every so many seconds.
angusmcraptor
angusmcraptor
Miami, FL
Looks good. Checked it out and like that it shows 2 parameters. Also, checked the parameter sheet and it's pretty extensive.
Jace21583
Check out the banks iDash 1.8 gauge. Simple plug and play into obd2 port and you can use it as a data logger.
