My Issues Post Cam Phaser Replacement
ffirgriff
Alaska
Yes I’ve always done the majority of the work on my vehicles but those were of the 2001 and 2002 variety. Things sure have changed in 20 years lol. No way I would attempt a phaser job. Hell, I’m not even sure I have the ability to do spark plugs on this thing . The engines these days are tucked so far back it’s hard to access those rear cylinders.
Therock88
Office Chair
Actually....The plugs and coils on these can be done in about 20 minutes...No kidding. Easiest I have ever seen.
Just FYI
DC
Edit: Thought a Picture may help :)
Trailmaker
Off-road junky
Conroe Texas
Just FYI
DC
What size socket was it again? I took the cover off to see that the plug is deep and will require a pug socket with the rubber, to pull out the old one. So I need to buy one to do my plug replacement.
Therock88
Office Chair
Should be 8 MM for the coil packs, and 5/8 INCH deep socket for the spark plugs. You can also use one of those magnetic fishing/extension tools to get them out.
DC
Trailmaker
Off-road junky
Conroe Texas
DC
Thanks. Got the socket on the way home and got my plugs changed. They look pretty good for 113k! I’m embarrass as I normally go 60k on a set. My truck, (besides phaser rattle) has been flawless as the tires, brakes and oil is the only thing that has been changed. I am on the lookout for a CO 37 so I’m not sure if I will change all the other fluids. But if I did, I would take it to 200k!!
mymichi81
riverside
I just bought a 2022 Wildtrack and it makes a similar noise. I have a warranty and i am hoping that it can be easily fixed.
